E39 530d
yoginn
I have found that the rear suspension has ended up with a positive camber (about 2 years ago). this was adjusted and aligned by Autowiel in Centurion.
I do see that problem resurfacing - Any pointers as to what components need to be replaced ?
ChefDJ
Negative camber.....
My car has it too, and I'm advised that it may be caused by the ball joints which I will be checking this Friday. Maybe get your shocks tested, and have your ball joints checked at the same time
:thumbs:
yoginn
:thumbs:
Thanks - Will do
LPM320
To my knowledge all BMW's have negative rear camber (designed that way), but not excessively so...
Negative rear camber will not be a symptom of suspension component failure alone, it would have to be accompanied by knocking noises, wobbles, squeaks, excessive tram lining, lack of grip and/or a floaty rear end.
anton-sa
guys for those with e39's. i have a FULL very good set of suspension components, 4 x good shocks. 2 x rear sachs, 2 x monroe (the high performance one), front and rear swaybars, 4 x springs etc
5k onco
