e36 shudder under load
Guetzer
Hi gents!
My car started to shudder/vibrate heavily yesterday when under load, i.e. when im in gear and giving some gas. I suspect its either the guibo, propshaft centre bearing or rear cv's? I've had a look and cant see anything suspicious, there are some small cracks in the guibo but no tears or anything.
Does anyone know a decent place I can take the car to in the CT area to have this checked out?
Thanks!
Loom
If there are visible cracks on the propshaft coupling then it's long gone. I couldn't even see any cracks on mine but when I took it off it was obviously faulty.
Guetzer
serious? awesome thanks for the info! :thumbs:
Nikhil
+1 and only replace it with OEM! 1 hard launch with the replacement part and it will be in pieces
Guetzer
sweet thanks! any idea what they go for? this actually happend after a hard launch.. with some wheel spin maybe :fencelook:
Nikhil
Lmao I know all to well about that, Oem goes for +- R1200,00 when i bought it over a year ago from Bmw. Maybe ask for a discount
Doomsdaya
That's not too bad, I was expecting worse...
Guetzer
Ok so the propshaft doesnt vibrate under load, more like when the revs run down from around 3000 to 1500rpm it stars to really shake everything. the guibo seems to be ok, the center bearing seems to be ok but the rear universal joint seems to be a little bit stuffed.
Is there any place anyone can recommend i take the car to please guys!?
Nikhil
Hmmm apparently garage 808 is good. This sounds like the dual mass fly wheel now or a mounting of some sort.
Guetzer
Thanks, I trying to get hold of them since 8am but they dont answer both numbers they list on their facebook page. :argh:
