calypso said:
Your oil temp get to 150?
No mine would be around 100-110 on a hot day, but im sure when u doing track it will go higher.
Castrol edge should be good for temps around 110-120deg
but thats cutting it to close imo, hence recommended is edge sport which should be good for higher temps.
I know with the wrong oil if the oil temp gets to high u can and prob will run bearings as the oil can no longer provide enough protection.
Point is he has no oil cooler so his oil temps will be higher than ours right?
calypso said:
If I recall user manual says if you get to 130 then chill out
Definitely, and to my knowledge if u are running a 5-40 oil at this point that reading can be followed by the dreaded rumbling sound.
