E36 M3 Mods
B16A4
Lysis@Axis said:
B16A4 said:
I really struggle to see how it can run strong with a 3.2 ECU? Maybe yu got a 3.0 ecu, im sorry there is no way yu can run nicely with a 3.2 ecu. If you are running it the its on alpha mode and just dumping fuel coz it cant find the right sensors. Fit the right ecu and be sorted, i dnt knw how evryone skipped to tell yu this.
This isn't something which has been skipped over.
V'Nolan, just to clear up something in your last post; your head gasket is fine. Your tappet cover gasket is what needs changing, it was leaking oil into the first cylinder spark plug if I recall correctly.
Thank you lysis for the correction. As per post #12 where the author posted what was picked up during diagnosis with the 3.2 ecu being there i felt it was important for him to make sure he has the right ecu for the car and harness. I believe it may solve his burning rich.
Apologies if you had mentioned to him before or my previous post sounde agro or offensive
:thumbs:
Jerez
Prini said:
My 2c, you can add all those mods, Cams, exhaust, cold air intake, and spend R10's of thousands, which will probably make it faster than a stock 4 door 3.2 E36 M3, but still slower than a stock E46 M3.
You will spend a lot of money for very little gain on the 3.0l. IF you looking for more power, you have to supercharge or turbo charge.
TRUE- Dont forget to upgrade your brakes too
