Doomsdaya
This problem been going on for quite some time now & its irritating me :argh:
Put key in ignition, turn till the lights come on and twist to start and it cuts out (everything just goes dead).... I than have to go & play with positive battery terminal till the boot light goes on and try and start it again. I must repeat this process like several times before the car eventually starts.
At first I thought it was the battery causing this, so I had the battery replaced but problem still persists. When it cuts out at first, I get a foul smell from the battery..... is that a sign of a short or could this be a faulty terminal or is the alternator on its way out ?
