E36 328i INPA CAN'T ACCESS ALL MODULES
Hi there. I have Inpa and DIS installed working 100% on my E46 320d. On my E36 328i 1995 it is a different story. I can only access the engine and NO other modules. I tried to change the interface within the Ediabas.ini to STD=ADS but still no luck. Should I try a complete fresh install? I am completely out of ideas and google is not much help.
Regards,
444YYY@TheFanatics said:
Just to confirm, you need an ADS interface adapter. Which one are you using?
Thats where my thecnical limitations come in. I dont have a a true serial port, so I'm using a eBay usb dcan kline cable wich i used for my e46. Then afterwards i just bought the 20 pin round adapter. Do i need a yrue ads interface?
wikked
Banned
I have a serial ADS interface you could try, but I'm based in Cape Town. AFAIK E36s only play nice with a proper ADS interface
Thanks for the offer, but I'm in gauteng. My laptop doesn't have a serial port. Usb only. Is any kind of a work around?
wikked
Banned
None that I am aware of.
Donovan2412
Best way would be to find someone selling a cheap old laptop with a serial port.
Thanks for all the advise. If i do find one with serial port, where would i be able to find the ads interface locally or would it be eBay only?
wikked
Banned
Try and pick up a Dell D630. I managed to source a refurbished one quite cheap
wikked
Banned
EBay. See my pm. I'll send you a pic later of what my interface looks like
444YYY
You need a true ADS interface which works with a PC with serial port.
The adapter cable between the round a square adapter will do nothing if you don't have an ADS interface.
I have bought the 'Tiny ADS' interface off eBay. It works.
Also you get a switchable ADS and OB2 cable of eBay too..
