E36 328i fuel consumption shocker
Spy007
L~C~G said:
My 328i would get me 480km - 500km before the reserve light would come on regardless of if I drive gently or thrashed her so i gave up trying to save fuel.
Its no fun to drive gently so why bother for the tiny saving you may get.
My 320d gets 850km before the reserve light comes on with mixed driving. if i really push her the consumption goes up badly!
Tbag gets 7 if I drive it Hard i get 7.5.
How badly does yours go up?
hanopp
i drove a E36 328i for more than a year, and yes the best we got on open road was 13.2km/liter BRILLIANT!!!!! and 10km/l in town, what a awesome car!!
Dhp507
My 98 318is with a bad O2 sensor use to get into the 8-9 l/100km Highway & town around 10-11l/100km. Current ride 04 320d with software is 6l/100km Highway & 6.4 - 6.8 town. an thats fisting it every so often dont see more then 7L/100km.
Space86
Did you replace your O2 sensor? If so, where?
Dhp507
Didnt replace it. Had the cat removed and installed a Doug Wallace Exhaust so used a fooler. Though if you looking to sort it out they are people that do aftermarket . Though if your cats are blocked no use having the o2. Should you replace the cat with a 75cm resonator and then install a new sensor OR fooler.
Baps
Yuvan said:
I seldom drive enthusiastically and my 328i cabrio's consumption is exactly the same, sometimes it goes into the 9's!
I can back that up. I get the same on my E36 328i vert. Trips to Durbs sometimes produce consumption figures in the low 8's.
Mr.k
Fooler? can u xplain please?
Ashy87
on my obc the consumption does not show at all.
It does show the range and the faults just not the consumption any ideas how i can fix it?
Dhp507
Tricks the ecu into beliving the values which are measured are in range. Do a google search to gain more insight. I know there are even options to move the sensor out of the direct flow of the exhaust think of a weldolet OR branch fitting that the sensor is installed to then attached to the exhaust. What is it that you are having an issue with specifically maybe then we propose a solution
Mr.k
my o2 sensor is shot, was looking to replace it but its dammmmn expensive + i need to change my maf sensor... im a student so R1200 is quite alot of money
Dhp507
Unfortunately thats one of the perils of owning a BMW.:cry:
Just save up and or ask a family memeber to front you so you can sort it out. Its going to cost you in the fuel bill anyhow and the bad performance (limp mode). I suggest you look into the fooler also. Once that O2 is sorted it should last you another 80K to 100K easy
Read the extract below
Some very new cars are using a different style sensor that is powered. *Many* Oxygen sensors are replaced that are good to excellent. *Many* people don’t know how to test them. They routinely last 50,000 or more miles, and if the engine is in good shape, can last the life of the car.
What does the O2 sensor do?
It is the primary measurement device for the fuel control computer in your car to know if the engine is too rich or too lean. The O2 sensor is active anytime it is hot enough, but the computer only uses this information in the closed loop mode. Closed loop is the operating mode where all engine control sensors including the Oxygen sensor are used to get best fuel economy, lowest emissions, and good power
Should the O2 sensor be replaced when the sensor light comes on in your car?
Probably not, but you should test it to make sure it is alive and well. This assumes that the light you see is simply an emissions service reminder light and not a failure light. A reminder light is triggered by a mileage event (20-40,000 miles usually) or something like 2000 key start cycles. EGR dash lights usually fall into the reminder category. Consult your owners manual, auto repair manual, dealer, or repair shop for help on what your light means.
How do I know if my O2 sensor may be bad?
If your car has lost several miles per gallon of fuel economy and the usual tune up steps do not improve it. This *is not* a pointer to O2 failure, it just brings up the possibility. Vacuum leaks and ignition problems are common fuel economy destroyers. As mentioned by others, the on board computer may also set one of several failure “codes”. If the computer has issued a code pertaining to the O2 sensor, the sensor and it’s wiring should be tested. Usually when the sensor is bad, the engine will show some loss of power, and will not seem to respond quickly.
What will damage my O2 sensor?
Home or professional auto repairs that have used silicone gasket sealer that is not specifically labeled “Oxygen sensor safe”, “Sensor safe”, or something similar, if used in an area that is connected to the crankcase. This includes valve covers, oil pan, or nearly any other gasket or seal that controls engine oil. Leaded fuel will ruin the O2 sensor in a short time. If a car is running rich over a long period, the sensor may become plugged up or even destroyed. Just shorting out the sensor output wire will not usually hurt the sensor. This simply grounds the output voltage to zero. Once the wiring is repaired, the circuit operates normally. Undercoating, antifreeze or oil on the *outside* surface of the sensor can kill it. See how does an Oxygen sensor work.
Will testing the O2 sensor hurt it?
Almost always, the answer is no. You must be careful to not *apply* voltage to the sensor, but measuring it’s output voltage is not harmful. As noted by other posters, a cheap voltmeter will not be accurate, but will cause no damage. This is *not* true if you try to measure the resistance of the sensor. Resistance measurements send voltage into a circuit and check the amount returning.
How does an O2 sensor work?
An Oxygen sensor is a chemical generator. It is constantly making a comparison between the Oxygen inside the exhaust manifold and air outside the engine. If this comparison shows little or no Oxygen in the exhaust manifold, a voltage is generated. The output of the sensor is usually between 0 and 1.1 volts. All spark combustion engines need the proper air fuel ratio to operate correctly. For gasoline this is 14.7 parts of air to one part of fuel. When the engine has more fuel than needed, all available Oxygen is consumed in the cylinder and gasses leaving through the exhaust contain almost no Oxygen. This sends out a voltage greater than 0.45 volts. If the engine is running lean, all fuel is burned, and the extra Oxygen leaves the cylinder and flows into the exhaust. In this case, the sensor voltage goes lower than 0.45 volts. Usually the output range seen seen is 0.2 to 0.7 volts.
The sensor does not begin to generate it’s full output until it reaches about 600 degrees F. Prior to this time the sensor is not conductive. It is as if the circuit between the sensor and computer is not complete. The mid point is about 0.45 volts. This is neither rich nor lean. A fully warm O2 sensor *will not spend any time at 0.45 volts*. In many cars, the computer sends out a bias voltage of 0.45 through the O2 sensor wire. If the sensor is not warm, or if the circuit is not complete, the computer picks up a steady 0.45 volts. Since the computer knows this is an “illegal” value, it judges the sensor to not be ready. It remains in open loop operation, and uses all sensors except the O2 to determine fuel delivery. Any time an engine is operated in open loop, it runs somewhat rich and makes more exhaust emissions. This translates into lost power, poor fuel economy and air pollution.
The O2 sensor is constantly in a state of transition between high and low voltage. Manufacturers call this crossing of the 0.45 volt mark O2 cross counts. The higher the number of O2 cross counts, the better the sensor and other parts of the computer control system are working. It is important to remember that the O2 sensor is comparing the amount of Oxygen inside and outside the engine. If the outside of the sensor should become blocked, or coated with oil, sound insulation, undercoating or antifreeze, (among other things), this comparison is not possible.
How can I test my O2 sensor?
They can be tested both in the car and out. If you have a high impedance volt meter, the procedure is fairly simple. It will help you to have some background on the way the sensor does it’s job. Read how does an O2 sensor work first.
Testing O2 sensors that are installed
The engine must first be fully warm. If you have a defective thermostat, this test may not be possible due to a minimum temperature required for closed loop operation. Attach the positive lead of a high impedance DC voltmeter to the Oxygen sensor output wire. This wire should remain attached to the computer. You will have to back probe the connection or use a jumper wire to get access. The negative lead should be attached to a good clean ground on the engine block or accessory bracket. Cheap voltmeters will not give accurate results because they load down the circuit and absorb the voltage that they are attempting to measure. A acceptable value is 1,000,000 ohms/volt or more on the DC voltage. Most (if not all) digital voltmeters meet this need. Few (if any) non-powered analog (needle style) voltmeters do. Check the specs for your meter to find out. Set your meter to look for 1 volt DC. Many late model cars use a heated O2 sensor. These have either two or three wires instead of one. Heated sensors will have 12 volts on one lead, ground on the other, and the sensor signal on the third. If you have two or three wires, use a 15 or higher volt scale on the meter until you know which is the sensor output wire.
When you turn the key on, do not start the engine. You should see a change in voltage on the meter in most late model cars. If not, check your connections. Next, check your leads to make sure you won’t wrap up any wires in the belts, etc. then start the engine. You should run the engine above 2000 rpm for two minutes to warm the O2 sensor and try to get into closed loop. Closed loop operation is indicated by the sensor showing several cross counts per second. It may help to rev the engine between idle and about 3000 rpm several times. The computer recognizes the sensor as hot and active once there are several cross counts.
You are looking for voltage to go above and below 0.45 volts. If you see less than 0.2 and more than 0.7 volts and the value changes rapidly, you are through, your sensor is good. If not, is it steady high (> 0.45) near 0.45 or steady low.
Testing O2 sensors on the workbench.
Use a high impedance DC voltmeter as above. Clamp the sensor in a vice, or use a plier or vice-grip to hold it. Clamp your negative voltmeter lead to the case, and the positive to the output wire. Use a propane torch set to high and the inner blue flame tip to heat the fluted or perforated area of the sensor. You should see a DC voltage of at least 0.6 within 20 seconds. If not, most likely cause is open circuit internally or lead fouling. If OK so far, remove from flame. You should see a drop to under 0.1 volt within 4 seconds. If not likely silicone fouled. If still OK, heat for two full minutes and watch for drops in voltage. Sometimes, the internal connections will open up under heat. This is the same a loose wire and is a failure. If the sensor is OK at this point, and will switch from high to low quickly as you move the flame, the sensor is good. Bear in mind that good or bad is relative, with port fuel injection needing faster information than carbureted systems.
ANY O2 sensor that will generate 0.9 volts or more when heated, show 0.1 volts or less within one second of flame removal, AND pass the two minute heat test is good regardless of age. When replacing a sensor, don’t miss the opportunity to use the test above on the replacement. This will calibrate your evaluation skills and save you money in the future. There is almost always *no* benefit in replacing an oxygen sensor that will pass the test in the first line of this paragraph.
W
wikk3d88
A little off topic..
My gran has a E36 325iA.
Couple years ago i did a trip down to durban, managed to get 9.0L/100km (according to the OBC), cruising at around 110-125km/h. Usually i love giving that car the beans, but by just changing my driving style i was pleasantly surprised at the consumption.
Dhp507
No use owing a four pot and driving it hard all the time you will avg out 12-14L/100km. I say better having a 6 or 8 cyl. You wont need to thrash it as it would suit your Driving Style/power requirements better plus the engine will last longer.
Some dont see the practicallity of owning a larger displacement engine. All depends on how you want to use it.........:idea:
W
wikk3d88
The 325iA has horrible in-traffic consumption.. Would love to buy it but ill have to wait until i have a proper job.
Space86
I've replaced my stock exhaust with a TNT stainless steal exhaust (decat). Did this after 3 months of owning my 318is, fuel consumption barely changed...(maybe my foot got heavier)
Dhp507
All good so have you tested to see if its faulty or going on the merit that due to the change in the zorhaust. You would somehow improve you comsumption. If not then I can say you just want to hear that cool howl coming out the back :joy:
Dhp507
Mr.k said:
would changing the 'branch' and xhaust make a difference?
The factory Branch is quite good ..though the exhaust can see some improvement if done correctly. I would personally look into port and polish the heads to give that improved response/power. It all really depends how far you want to take it .......
well how much money you got to throw at the car.
