Solo Man
How difficult is it to replace the oil seal on the pulley side of the crank on the E36 318iS? Seems as if mine has started leaking there and i would like to replace the seal. I think i have read somewhere that the bolt holding the pulley onto the crank is quite a tough one to loosen. Is that correct? Is there a special tool to hold the pulley/crank in position when you loosen the nut or is it something you can loosen by putting the car in gear and have someone step on the brakes while i loosen the nut? Fortunately there is quite a lot of room between the engine and the radiator.
