e36 316i engine swapped to e36 m50 325i
dylanwm1
Hi I need some help please. I recently got tired of having to drop gears with the 316i so I swapped it to a m50 325i. Car is running good just with a few hickups I can't find. I swapped the engine, ecu, exhaust, engine harness and onboard 18 button. I need help with a few things.
1: when the ignition is switched on the fuel pump relay clicks the whole time on and off.
2: before I can drive the car I have to rev it completely open before it has enough power to pull off. Getting annoying
3: need to change the engine factor on the cluster from 2 to 3 for the 6 cyl. Right now it looks like its revving up to 10000 rpm! Looks cool but its out!
Any advice would help, I've had it on a diagnostic, no errors in system.
Thanks in advance
