E36 2 Door Convertible Driver Window problem
neelsie88
Hi.
On the driver side with the electric window I got some sort of problem.
I know when you open and close the door the window opens a bit. That works. But when I drive and the window is open everything is fine but when I drive and close the window you can hear the window motor every now and then trying to to domething, then after a while the window does not want to open again. Can only open it again after the car has been parked for a few hours.
I am so Confused!!!
ZlinG
Sound like a electrical problem... maybe open the door panel and see whether it is not the motor itself that can be faulty, otherwise check your wires that goes to the motor
neelsie88
Found the problem! haha
It was the window switch on the door for when you open or close the door, it was a bit warn out
ClassicB
Hey i have a similar problem, please describe where the switch is situated on the door or a pic if you have of the switch. Where did you get a replacement switch?
neelsie88
Kwl, will take a pic and post and show
neelsie88
Here is a pic of the switch, and what I did to make it work again.
ClassicB
Hmmm I see, i thought the switch was attached to the door. Will go have a look & post if it sorted the issue.
@Nelsie88, I appreciate the help bud!!!
neelsie88
no problem! let me know how it is going
Clownshoe
I hear with the convertables there is a switch on roof that can also mess around and cause heaps of problems opening boot and locking. due to the logic system thinking the roof is down.
neelsie88
So far I am lucky then... Hope that mine does not give problems later on
Snoop328i
Hi Guys, had the same problem but i adjusted the whole switch (where the 2 bolts are) and that sorted mine out...:thumbsup:
neelsie88
It is so nice to see all the E36 Convertibles!!! How do I add a pic of mine in my signiture?
@Laigo No problem, we are here to help each other, well i hope so... hahaha
@Snoop328i Will keep that in mind!
Snoop328i
BTW some a$$hole stole my rear badge over the weekend...anyone have a spare laying around :)
Stealership quoted me R653 :cursin:
