zippy320
Hi guys!
So my E30 is now running , it still has that switching of problem for the life of me I cant understand why its doing that but anyway ..
While I was under the car , I thought about the diff , The oil in the diff has never ever been changed , I dont remember ever changing it , I dont remember my dad ever changing it . So Im assuming it has never been changed.
The car has over 300 000kms , Will it be safe if I change the oil? Or would I have problems with it after its changed?
While working on the E46 Transmission , the guy recommended I change the Diff oil on that car but I didnt get around to doing it so I have the oil that was meant for my E46 available to me .
The oil was purchased from the Dealership , Its marked Castrol Differential SAF-XO
and at the back it says SAE 75W-90 , I think this is the part number 33117695240
And i see here
http://www.realoem.com/bmw/enUS/partxref?q=33117695240
The the E30 is not listed on there .
Will it be safe to use on my E30 ?
If I Should I replace the oil , will It cause a problem later on? Considering its never had an oil change.
Thanks guys for all responses!
And i see here
