E20 mix daily
kcnyaka
Hi, anyone else using ethanol daily in a stock 335i?
Gusheshe fuels 25l is R370 which I use for 2 fill ups.
No logging or issues in the last 3months.
M3turbo
I have used consistenly in a B58 and a S55 - No issues.
If you want to really be safe from tank residual water problems, swap out the ethanol for 1 tank with isopropanol every 3-6 months i.e. run 20 % isopropanol instead of 20 % ethanol.
The ethanol price you mention is extremely cheap and below market price. Does your prcing include the 25 L container and do you know the water spec of this ethanol?
Jive_E46
Please elaborate on the residual water problems? May be some juicy bits in there that I might need.
Have you changed your fuel filter on the LPFP side at any point ?
Sent from my SM-G965F using Tapatalk
You'll see on the petrol cap that you can run e10 mix recommended by BMW. If you have the right tune you can run e30 mix as well max, after e30 your LPFP starts to eat itself inside out. e20 should be perfect.
Kish2604
Administrator
Shrugs my shoulders and laughs to myself on the awesomeness of the advice on this thread..
bybyM3
Parafin will give you even better results... I have used it now on 4 tanks.. No issues no need to log either
Jive_E46
Depends which part was funny...lol
Twinz
Forum - Support
I have been using ethanol in my 335i(s) N54 since 2007....up to 85%
A 55% mix works well to prevent the winter blues on cold starts.
I also used an eth mix when my car was stock - so long ago. :smilebounce:
Great thing is with all the modern tech/tuning such as the motiv flex fuel kit & the Mhd module the DME will adapt to whatever mix is in the car...no need to change tunes for an eth mix or for pump fuel just fill up and go and the Dme takes care of the tuning.
M3turbo
Ethanol is hygroscopic i.e. it absorbs mositure from the air. if enough moisture is absorbed, eventually water will separate out. Even ehanol stored in plastic drums are prone to absorbing water.
Mr Admin, is it too much to ask of you to be a a bit more constructive?
Exactly which part are you belittling?
@Jive_m135i, your fuel trims will guide you on the max ethanol you will be able t0 run. There should not be a major difference between E20 and E30 and your fuel system is well capable of handling higher amounts of ethanol with respect to corrosion.
Jive_E46
Thanks for the advice :D . My main concern is actually putting the LPFP under too much strain, due to the fact that alot more ethanol is sucked in to the fuel system compared to petrol, affecting the LPFP duty cycle and lifespan.
1.What values would indicate the LPFP reaching its maximum flow ito ethanol used?
2. If I am running WMI what values for trim should I be looking for to find the perfect balance of ethanol? If my WMI is too rich my trims go negative, adding distilled water does the trick(FF=40)
I've never really used ethanol before only UCB Racing octane boosters(Napalm for a weaker mix and Thermite for a strong mix), which are ethanol free. With a mix ratio of 5L to 20L these octane boosters give me a Fuel octane of 102-106 RON which is more than enough to run 20 PSI+ boost.
kcnyaka
R450 with container.
