E12 and classic BMW vins
rodga
I'm looking to get some vehicle info. It's e12/8 with the short vin sequence. BMW the Glen couldn't pick it up on their system. They used the last 7 digits which throws out 60's motorcycle. Any ideas?
Sent from my MI 8 using Tapatalk
NtandoN
I’m not sure about vehicle info. But parts for my e30 are normally found under classics platform on the bmw system and they use the full VIN.
rodga
Thanks does your e30 have a 17 digit vin or is it shorter?
M-factor
try M decoder which lets you input the shorter 7 digit VIN. In the results, it should return the long VIN for the car
M-factor
For parts info, realoem.com is helpful in finding part numbers, giving indicative pricing (usually with up to +-20% variance) and letting you know if parts are still available from agents.
rodga
Same result as all the other decoders.
