devster
Hi, my car has had the trifecta lights of yellow abs yellow DSc and red handbrake lights. I had the abs/DSc module “repaired”, by a gentleman in the northern suburbs of Cape Town.
It wasnt, since after the repair it then showed yellow DSc and handbrake light. I took it to another shop to rediagnose and fix.
The fault code coming up now refers only to 5df0; valves. No DSc connector fault.
The new shop had the system checked, brakes bled, and programmed via an autel system in case it needed it(it shouldn’t since it’s the same unit). No luck. The new shop says it’s the valves. The original repairer says it’s not the valves, that he fixed them.
I’m throwing money at a problem quite quickly here, and it not being fixed. With hindsight, I should have taken it to the agents, but I’m now deep down this hole. Who would you recommend to fix this, without resorting to the agents? In Cape Town, south suburbs ideally, but northern suburbs can work.
