rick540 said:
moranor said:
rather stick with the oem floating disks I can Cryo treat a set for you it will make them last 2-3 times longer so then you can run high friction pads on them and they wont get eaten... your other option is to look at other floating disk upgrades, but they are going to be pricy...
Any downside to this, was just wondering why they don't do that from the factory?
there is no industrial way to do it so it takes time... so it can only be used in small scale right now... but it was the same with heat treatment and now they just have a huge conveyer belt goes in soft one side and comes out perfect the other side...
I know of two race teams (they cannot be named :fencelook: ) that are using this treatment (they are unable to change disks because of rules)...
before they would go though a set of disks a race, but now they can run 3-4 races whit the same disks...
the only down side is the cost, but with the disks lasting longer it makes up for the cost... I think the reason why manufacturers dont do it is because they will increase the cost of the product and im not sure it makes sense in terms of marketing...
