low_flyer said:
Mc Member. said:
I personally don't see the connection between the MAF and the sudden diesel smell?
Unless other work was done perhaps?
check for leaks on the exhaust and around the cat
[/quote
Hi there. I have just been to the garage and they checked for leaks but found none. Thr mentioned
That the catilique is blocked. He suggested they cut out a portion of pipe and remove the catalique. I am not sure if this is possible?
Been doing some research on this.
They may be referring to the particulate filter.
There is a down pipe which can be put in BUT I would recommend using someone who knows what they are actually doing IMHO.
Whilst there, get the software done at the same time?
In fact, go the whole nine yards, pull the back box off and replace it with a straight pipe, pop a down pipe in and get the software done.
Sideline question:
Has there been a drop in power and an increase in diesel consumption?
