Detailing : Lambchop Vs 1M
lambchop
Fraser said:
I've heard a runout that Lambchop just likes looking at himself a lot, thus the motivation behind his really good work.
Just a rumour mind you
I had a shave using the bonnet this morning :)
Scouse
What can I say except AWESOME AWESOME AWESOME
Excellent work mate as usual, you have really made a sick car look even sicker :praise:
Well done:thumbs:
prospect
Fantastic job on an epic car :thumbs:
Rowen, do you have a video of your car's sound with that exhaust?
Kyle
Wheres that spider? :fencelook:
Sent from the Death Star
All aspiring detailers, this is how to post a proper detail thread :thumbs:
Speedy
Lambchop what great work man, wow is all I can say.
What speeds do you usually work with and how many passes on avg do you use?
lambchop
Cheers Bud :thumbs:
Normally 2 passes on average depending on the type of damage on the paint
With the RUPES i use between speeds 3 or 4 when correcting
sash
Absolutely stunning lamb chop.
I know you cleaned those akra slip on tail pieces, any afters on that?
Fraser
Popped back in this morning for another look to get some motivation.
At the risk of sounding like an arse licker, your work is inspirational.
:praise:
RowenS
Right then,
I fetched the car a couple hours back. The workmanship is of the highest quality.
Just as I expected. Thank you Nick, and more especially for having to put down your tools and scan the dyno graphs that I left in the car. :rollsmile: You have a lot of patience my friend.
:thumbs::thumbs:
Concours time! :joy:
lambchop
Rowen said:
Right then,
:thumbs::thumbs:
It's a pleasure Rowen. Thank you for giving me the opportunity to detail your car
Now to win some trophies :thumbs:
Peter@AEW
Excellent work and attention to detail.
Especially enjoyed the use of the paint thickness meter which I would suspect most do not have.
lambchop
E28 Boy said:
Nice work - what were the paint thickness readings after the correction?
i have honestly never take a pic of the after reading.
Simply because i never measure the same spot i took the measurement from.. Poor form I know. I need a laser pointer to measure the same spot i took the reading from. I normally just take an average reading of the section i polish. So for a door ill break it into 4 sections and measure each quarter
but you only removing between 2-5 micron when you correct the paint
Ill measure this weekend and confirm
Onyx said:
Awesome... but that's what we've come to expect. :thumbs:
Thats the problem lol
I cant lower the bar now :)
Pravin@crazydetailer
Lovely write up and awesome results there!
There's no better praise like confidence from a fellow detailer!
lambchop
AeroEng said:
:praise:
Your work has always been top notch, but I think you've exceeded yourself on this detail. :thumbs:
Thanks :thumbs:
I decided to take enough pictures this time to document what real detailing is capable of.
The process i use hasnt changed but i took time to take more pictures
AeroEng
lambchop said:
AeroEng said:
:praise:
Thanks :thumbs:
Think you should always take as many pics, shows the true effect of your work.
Just a quick question - are you able to remove the defects for VPS? I was always under the impression that one could not achieve the same level of correction?
