nicwes
A few things went wrong about 6 weeks ago.
The 'List' from BMW
These I only have the abbreviation
Page 2
TOTAL: R37299.50 (incl. VAT)
The 'List' from BMW
- 1. PRESSURE TEST CYLINDER HEAD AND REPORT - R4548.20
- 2. Disassemble cylinder head and assemble, check valve seals and sample contact pattern - R6734.59
- 3. Replacing Radiator - 327.12
- 4. Removing and installing or replacing coolant thermostat - R204.45
- 5. Removing and installing or replacing coolant xpansion tank - R81.87
- 6. Replacing engine oil level switch - R327.12
- 7. Replacing pulse generator on exhaust camshaft - R40.89
- 8. Removing and installing or replacing water pump - R368.01
- 9. Bleeding and checking cooling system for leaks - R204.45
- 10. Wash - R30
- 11. GUIDE RAIL M - R40
- 12. HEATER IN-PI - R328.64
- 13. THERMOSTAT 258i '99 - R1077.97
- 14. C/HEAD GASKET - R3321.03
- 15. ABSORBING PIPE - R 70.68
- 16. GASKET+HEAT - R701.50
- 17. CYL. HEAD. GASKET - R1191.89
- 18. TORX BOLT M6 - R11.55
- 19. TORX BOLT M6 - R11.55
Page 2
- 20. TORX BOLT M6 - R 17.65
- 21. CYL. HEAD BO - R472.24
- 22. BOSCH PLUG - R402.99
- 23. SPARK PLUG - R217.48
- 24. RADIATOR 30l - R1885.75
- 25. ADJ SCREW E46 - R65.96
- 26. EXPANS TANK - R963.34
- 27. OIL FILTER E38/E46 - R104.3
- 28. BMW COOLANT ANTIFREE - R125.03
- 29. BLEEDER - R37.89
- 30. CAS/PROF 100ML BULK - R416
- 31. VENT HOSE - R 181.07
- 32. AIR FILTER E36/E46 - R97.39
- 33. OIL LEVEL SENSOR - R1750.13
- 34. PULSE GENERA - R1301.69
- 35. AT-WATER PUMP E39 - R1221.45
- 36. Surcharge on above - R150
- 37. HOSE RAD-CYL - R395.26
- 38. CHAIN TENSIO - R595.39
- 39. SHAFT SEAL 4 - R185.58
- 40. LWR CVR GASK - R68.83
- 41. CYL. HEAD GA - R1191.89
- 42. CYL. HEAD BO - R472.24
- 43. V-BELT 6PK X 1538 E46 - R383.89
- 44. CAS/PROF 100ML. BULK - R64.03
