this is why I dont like metal impeller pumps if the bearing fails the impeller will damage the block...
moranor@axis said:this is why I dont like metal impeller pumps if the bearing fails the impeller will damage the block...
sash said:have you put the car on a lift and do a bit of shaking on the above mentioned parts....?
You have come this far.., maybe it might be better to replace the last two bits.., lol
moranor@axis said:suspension bind will do that![]()
moranor@axis said:well you have almost replaced the full suspension![]()
Rotinaj said:Wood trim must go with the 3 spoke wood wheel.
