Crank, no start
Hi guys. I have a 2011 320i. Just out of nowhere my vehicle cranks, but theres no start. There seems to be no power going to the fuel pump. I ran power directly from the battery to the pump and she starts up just fine. I had ISTA on but not getting any error codes as to what the culprit might be.
dhvnr5901
I would check for a blown fuse, a broken wire going to the pump or maybe an inline fuse if it has one. Run a continuity test on your wire going to your pump sounds like something broke.
Sent from my F9 using Tapatalk
Just an update. After chatting with Gert from Obdworx and pointing me in the right direction. The fuel pump realy is a fixed relay thats soldered to the fusebox pcb. I just swapped out the fusebox and problem solved.
