cracked head
iknowuloveme
so my car caved in and sounds like a truck...took it to the mac, he says its a cracked head and wants R11 200 to repair the head...
so im wondering if there isnt any other alternative, or any of you guys have a spare m52 head up 4 grabs...thanks
sykotic
the guy is ripping you off. for that price you can get a 2nd hand head thats in good condition, fit it on and have cash to spare! if its a slight crack, repair it, but if its a bit more serious, rather get a new one. thats what i did, cause if its not welded properly, itl just get stuffed again.
MPloyer
You can also try JR cylinder head services.
Tel : 011 885 3506 Speak to Wayne. They could possibly also help you source a second hand one or repair yours.
iknowuloveme
thanks guys...was thinkig for eleven thou, i could flow my head, do valve springs and mayb cams...plus purchase a good condition head
STREETRACER
for R11k you can make that a machine!! contact my man GIZMO he will be able to hook you up with a head!!! then you can send it my way if you want some proper port and pollishing!!! i would rather spent the cams money on your diff!!!
Money vs gains diff will make the biggest difference!
Maybe 3angle your valves seats and up the compression! while head is off ballance bottom end and bull nose your crank!
you will need one of those Midas Boot spoilers to keep it on the road LOL:slap:
zaleonardz
Actually street.
I have some noisy lifters in my E34, and considering having both heads rebuilt with a port and polish.. how much am I looking at just as an indication, that mod is still a long way off.
Hellas
Ok, ok, ok. Everbody is getting carried away here. If you got quoted R50 000, but can fix the head for a grand, it does not mean that you HAVE to go spend the remaining R49k 'that you WOULD have paid'...
good luck on saving a buck, but save the rest if you can.
STREETRACER
zaleonardz said:
Actually street.
About R350 per port!!!
iknowuloveme
@streetracer...already bought the 3.64 diff, from gizmo..loving the rainy days...as for the porting, i'll keep in mind...not looking to spend the all the cash, just taking advantage of the situation, as i seriously don't wanna have my car back in the garage..
STREETRACER
ahh nice so it should be quite perky!!! na i was just going over board!!
You can get it fixed up for small change dont need to empty ur wallet!!!
