Hi guys.
Hope someone will be able to give me some advice.
Sorry in advance for the long essay
My wife's X3 2.0d (e83) was diagnosed with a faulty turbo about a month or so ago. Long story short, the car was repaired for her, by one of our family members, but i am not sure the mech he took it to knows BMW's.
When the X3 was diagnosed, it was smoking alot, darkish plumes of smoke were coming from the exhaust, and the car was using a bit of oil (a pint every 1500Km or so)
Turbo was replaced, but the mech didn't change the oil. So I did an oil change when we got the car back. the car was still smoking a lot, I was told that the car needs to be driven so that the oil can burn out of the exhaust system/catalytic converter - Mech told the us not to decat it.
3000kms onwards, and the car is smoking worse than ever.
X is using more oil than i've ever used between services (2litres over the last 1000km)
It randomly looses boost, then when i drop down a few gears it slowly builds up boost pressure and the turbo slowly comes into life again, then it will be fine for a few kilometres, and then does the same thing again.
The turbo makes a grinding noise between 2500 and 3500 rpm after second gear (not sure if it is the turbo, but only when the turbo kicks in does it make that sound)
I took the car back to the mech, and he says that its probably one of the rings that have collapsed. I'm not so sure...
everything was fine before the turbo was replaced
Could all this still point to the Turbo being the issue, as i am not sure if he put a recon unit in, or if the turbo seal is leaking. Oh, and the exhaust developed a hole in it. Going to have it looked at when i have the courage to drive it again.
I am now scared to let the wife drive the car for fear of something else breaking, and it costing us another arm and leg.:blueCry:
