I'm on 122000kms and not a single problem with my turbo, had the car since new and look after it... the only problem I have had was when I purchased the car it came with a squeak... which resulted in the crank pulley... other than that, you should expect your common running parts (as with all) to give way at some point... pulleys, v-belts, tensioners etc other than that, loving mine
