Chef's E39 530d
sash
thats sounds wicked Dylan
anton-sa said:
sounds good. i wonder what the effect and or sound would be like if you removed the center box and left the rear box in place ??/
i have a similar setup on mine, although not a stock rear box. It does sound different, a bit deeper maybe?
ChefDJ
I still feel the sound isn't right for the type of car :fencelook:
I may fit a smaller backbox on at some stage...
Nikhil
it sounds awesome stop being an old man :fencelook:
sash
I hope this works...It has gotten deeper since these videos
if it doesnt work then will correct later at home as i cannot access youtube from the office.
ChefDJ
It works, and your car sounds epic :praise:
German_spec said:
Chef, does bmwtalk know you fitted a downpipe :fishwack:
For the hundredth time, I am not on that forum :facepalm:
Nikhil
ChefDJ said:
So... The new alternator didn't help the loud whine in the mornings.
Im suspecting crank pulley or viscous fan. Have you flushed your power steering system?
ChefDJ
Both checked and fine.
I know a power steering whine. It's not that.
It's been going on for over a year now.
Nikhil
My crank pulley looked fine visually but was making a bit of noise for some reason, replaced it and the noise is gone. In terms of the pump it doesn’t always wine , most of these cars are over 10years old so a fluid change can only be of benefit even if it doesn’t solve the issue. :rollsmile:
