Chef's E39 530d
ChefDJ
OppositeLockMT said:
ChefDJ said:
Oh and my car turned 260k this weekend :joy:
Was just about to ask what your mileage is.
Have there been any transmission repairs throughout its lifetime? I always worry my gearbox is going to go kaput.
Your E39 is still looking clean. :thumbs:
None that I'm aware of. No comments on motorplan history either.
anton-sa
well my e39 530d is manual, its now just on 286 000km, last week one evening i drove to capetown cbd to go visit a friend, as i pulled up on their driveway i heard the aux fan going nuts... about 2 or 3 hours later i left and noticed the temp needle smack bang in the middle, weird as usually the car temp would have dropped a bit...
it was like 12c out.
so on my way home as im on the highway i see the temp needle starting to climb to the red, i switch off, let her cool off... repeat process
eventully some 25km further (which took the best part of a hour to drive)
i got to another friends place (much closer than my home)
left the car there, next day had it towed to garage etc..
turned out my oil cooler packed up and contaminated the entire cooling system with oil.... E I S H
ChefDJ
I watched the temp guage like a hawk, trust me. It's very stressful towing 2 tons and your car suddenly loses power.
ChefDJ
herr bmw said:
I told you I was available to tow it down with the Navara,but no you wouldn't listen,would you:fencelook:
The boost leak could have occurred at any time :fishwack:
herr bmw
.......... but not on the way down to the coast.........
better be careful,might get banned for dishing the e39 mafia
Navara rules:fencelook:
ChefDJ
A major thanks to Gordon and Rob for assisting me with the vacuum leak. We quickly found the problem which seems to have been caused by an overly hot turbo.
BMW in Menlyn luckily had a replacement in stock, much to my disbelief.
Replacement was fairly simple, bar the odd angles of the screws and bolts. We had to remove the air filter housing and air intake pipes to get down there. Whilst down there we replaced the only remaining vacuum pipe that hadn't been done previously. We used the same fuel hose as before. I now have more peace of mind knowing that's done.
The booooooooost is back :joy:
Thanks again gents :ty::ty:
sash
good to hear it was a relatively painless exercise.
Chef, whats the name of the part being changed there? Is it just a different part from another model that fits on the e39, or do you think that the part was improved in later models?
edit... haha, i typed out my response while waiting for the full suize pics to show. I see it is an identical part.., in the thumbnails the damage made it seem like it was different. :flyfun:
ChefDJ
I have no idea if the part is universal or not. If it is, it's bad that a dealership would only have one in stock. I was so surprised to hear they actually had one when I phoned.
Why that part has to be plastic is also beyond me. I contemplated wrapping the thing in thermal sheeting to protect it from heat.
I'll be trying this week to have the downpipe done on the car. Will most likely go 76mm if I can afford it.
For the turbo to emit that much heat... Eish. :fencelook:
DieselFan
Sash it'd a vacuum canister. It stores vacuum so when you want to boost there is always sufficient vacuum to move the actuator. Well that's how I understand it.
The canister shouldn't have melted. Something else happened there.
