Spannie
The software for VAG does that, and I miss it so much! The BMW diagnostic software (well the ones I've tried) require that you know that the values SHOULD be, and then you can deduce on your own what's what. And getting info on BMW's on the net is also such a mess because you have people posting things like "I replaced parts x, y, z etc and that solved the problem for a while, but it came back and I found out it was actually just part w acting up".ChefDJ@TheFanatics said:Why can't diagnostics just tell you "listen poephol, there's a fault with this part. Replace it and you're good to go"...?
But I think the pre-supply is a little low on your car. I'll see if I can measure mine for you today
