Chef's E39 530d
Ralf*
ChefDJ said:
Andy1GP said:
Dyllan In the last pic it seems that your thermostat might have failed. If you've been driving for a while in that particular pic then it means its failed (open) and its not maintaining optimum temperature.
It's not a hard DIY either :) Thermostat should set one back around R700 incl the housing.
No no... :=):
I replaced the thermostat in December last year.
I had only been driving for around 10 minutes, on a highway.
My 530d also takes more than double the time to reach "normal operating temp" then the 740i, just a trip to the local Spar and the E38 is up to temp, the 530d would just barely be 1/2 way warmed for the same trip.
RAArmstrong
Ralf@Speedway Motorsport said:
No no... :=):
Yeah mine too... I get nearly all the way to Lanseria before it's up to temp... By that time there's no time for fun :(
ChefDJ
I need new badges for my key fobs. It's the 11mm badge and BMW don't sell them alone. I ordered from eBay but my parcel was accidentally shipped off to the other side of the world, so I got refunded.
Also, I have a friend that needs two. Also 11mm.
Where can I get other than eBay as I can't find the metal ones on eBay from a top rated seller anymore? They only sell the plastic ones and I don't want those.
Gizmo
Banned
Go visit Boetie Budler, he gave me some in the past.:thumbs:
ChefDJ
Okay, a shocking problem...
My front shocks make a weird noise when the front wheels hit a small ditch. In other words, going over a bump when the wheel is pushed upwards makes no noise. But when the wheel "falls" into a small ditch or after a bump, there's a noise.
It's not a creaking door type of noise, but more like a "whoop" noise. Dunno how to explain it. So I've decided it's time for a suspension makeover, and will probably do bushes too.
I'll contact Moranor for parts, but I need to find someone who can do all the work for me if I supply the parts.
Also, being the M-sport, I can't use standard E39 shocks and no one seems to have the stock M-sport ones. So, what do I use? And should I buy complete new control arms or just the upper and lower bushes?
ChefDJ
Tehwalleth said:
No luck at GW? JHB CBD's one is quite good at sourcing stuff for me.
Firstly, the brand they want to offer me is Topran :thumbdo:
Secondly, they only do the one set of bushes and not the other. I want to replace now to last me another 200k km.
uhem...?
See KPT :thumbs:
anton-sa
Hi, i had this predicament with my previous e39. it had msport suspension.
theres a place in capetown called gremeltech, also diesel electric, you can get the oem sachs shocks, same part, just the box isnt bmw branded. but its like 1/4 the price.
other option is koni sport shocks, yellows. im running them on my current e39, which is a 530d. previous car was 525i.
you wont need the h&r sport springs i have as you already have a bmw sport spring. issue i had with this current car is when i got it it had standard suspension.
ChefDJ
I'm guessing Koni will be my best bet.
Will it affect ride height? I like the stance of my car, so don't want it higher, but also don't want it lower as I have enough trouble scraping a few places as it is...
anton-sa
hi, mostly, springs are what effect ride height, keep your oem springs, keep your ride height.
the koni shocks will have the same travel or perhaps a little less than the sachs oem. i think it'll match up.
oh and choose the shocks for "540i". the heaviest of e39's.
anton-sa
ChefDJ said:
Which are those? I see koni sport and coil over and I dunno what else...
to be exact:
part nr: 9741 1341 sport x 2
part nr: 8240 1156 sport x 2
one is the front one is the rear..
