cat delete - any "heads up" ?
fluffy
seems like nobody has had issues with removing the cat... without even putting in a fooler or bung or mini cat...
but for now i've just slapped it on "as is"... HFC and all. the flex joint was damaged so i just had it replaced with another one.
Willy was Right... it sounds pretty awesome... i think a resonator in place of the cat might become too noisy even...
ters
ChefDJ said:
Middle aged man? Almost no hair?
No, Frans is mid/late 30's with plenty blond hair. Your description is nearly me.....except I have no hair!
Ters.
pre325
Hi guys iv just recently purchased a r53 cooper s,does a decat really make a different with power or exhaust tone ?
Willy
Minimal on stock tune and not a great deal after tune, but every bit helps in the end.
A good start would be pulley and exhaust with a tune.
I have a decatted manifold for you.
PM me if you want to try it out.
Willy
Import, but also check the UK guys after I bought in the ALTA one I saw a UK version for a bit less. But that was years ago. ALTA is probably the best place.
