Car wont start or Crank e46 323i EWS?
Shaheenem
Hey guys
New to the forum. Been mostly on BFC, e30clubsa and e46fanatics. Anyways, here's my problem,
My e46 323i (99 model) is giving me grief for the last coupe of years.
Long story short, car overheated and had to get the head redone etc.
The mech who did the head couldnt get the vanos/cams alligned so it was taken to bosch and they set/alligned whatever they needed to.
After getting the car back, the car has an intermittent problem with starting. Sometimes its starts with no issues other times it just doesnt even crank. Have to disconnect the battery and leave the car for a couple of hours and then maybe it will start.
Spoke to the stealers and they say EWS module and keys need to be replaced which they want to charge me R6500 - R7000 for.
Read up on a few threads on BFC and e46fanantics with different results. Some say cam position sensor others say EWS.
I dont have any diagnostic tools but i have taken the car to bosch to run a diagnostics previously. No errors were reported back to me.
StK
Where the sensors replaced? and if so with aftermarket or OEM sensors?I would advise getting a diagnostics done with a BMW specific scanner.Mine had a similar issue and turned out to be a dodgy sensor..unlikely to be an EWS issue
Shaheenem
I think the cam position sensor was replaced but i do not know whether my mech put in a new or used/OEM one.
Anyone willing to run a diagnostics on my car? In the midrand/centurion area...
ThomasM
Hi Shaheenem,
Did you eventually sort out this problem and how? I have 1999 e46 318i that has been giving me hell with the same problem. Starts fine when cold, but once warm or parked in the sun, no crank, nothing! Please help as i have tried everything. have replaced sensors, no luck, someone says its the ECU, another says its EWS, not sure anymore.
Thomas
