camshaft sensor?
noelrichard325
Good evening to every one ,i have a 325i 2001 e46, and am having some serioud prolems with it. i drive it in the morning , noproblem , then after about 3 hours (this does very) it starts to missfire, cuts out, wont start , sounds like its running on 3 cyliders,next morning all good , then the same happens.ive been told to replace the camshaft sensor intake,camshaft sensor exhaust, as well as the crank sensor,all these at once, seems like a lot of things for one fault.pls can someone help
D
Dippies
Welcome :thumbs:
You will get a better reply if you post it to the correct section so that all the members on the forum will c your post. :thumbs:
Nic_s
Moved to correct section.
Could be crank position sensor. Might even be dodgy wiring. Check all the wiring connections and plugs. It does sound like a dodgy sensor though.
calypso
An OBD reader will tell you exactly which of the sensors are bad. Just have the cars fault log pulled.
hoosain
my money would be on a coolant temperature sensor thats on its way out but the best thing to do is have the codes read
