BT Scan tool
laloosh
Hi guys I recently purchased the BT scan tool. I was just wondering how do I do afr logs and iat logs. Any help would be appreciated. Thanks in advance
Twinz
Forum - Support
Do you have a Jb3? Asking because you can do it with the JB.
You will need plenty of hard drive space to datalog with the BT and you will need someone to interpret the data off the BT.... I have been using the BT for almost 2 years and except for the code reading functions the rest is spanish...my local tuner fortunately does all that datalog stuff for me now.
Are you in C.T....?
laloosh
Thanks for the reply Twinz. I'm in dbn and I have CPI flash done on my car. Same here I tried fiddling with the tool but alas no joy. Think I just need to do more research on the subject.
Btw I haven't come across any stats on the jb3 in S.A. Was just wondering are the jb3 guys here getting the same results as the guys overseas and if so whens the jb4 coming out here?
Peejay
Events Organiser
Where did you get the tool from? What does it cost and is the software inculded? Sorry I'm of the topic
Twinz
Forum - Support
@Laloosh....Having George near by should assist you greatly with the BT. :thumbsup:
I should have added that I also have the BMS Can-Tool installed which allow me to do the afr/iat/timing on fuel/code read or clear & plenty other readings on my dash screen using the controls on my steering wheel, which makes the need for a laptop redundant.
But the BT is still great for comprehensive diagnostic purposes including coding if you have the professional version. There are some youtube videos showing the BMS Can-Tool in action and it works with any tune. Check it out.:thumbsup:
The JB4 is being tested at Alpha stage. Revo and I will start in the coming week and give you guys feedback. It seems the beta stage for the general public release is still uncertain.
Some users at altitude have not had joy with the JB3 due to the need to alter tuning settings for altitude use. At the coast and in particular the users in Cape Town have been running the tune very sucessfully; myself included.
The JB4 takes the juice box to a whole new level including for high altitude users because of all the grand new feautures which are not currently on the JB3 including the integrated Can-Tool which I mentioned above. So we are confident that the JB4 circle at altitude will increase. :thumbsup:
doods
is a tool like that used only if you have some mods on the car,
or can it be usefull on a standard one as well???
