Doomsdaya
Charlie Brown said:Agents if you don't want them squeaky.
:withStu:
Compared to the old ATE discs and pads I had before, I along with several other Bmw owners find OEM discs and pads on another level.
Gizmo said:Hope you like brake dust, dirty wheels and squealing brakes...
Did you measure the thickness of the rotor and compare it to the minimum thickness indicated on the rotor hat?
Charlie Brown said:Yip that sensor is done and will need to be replaced, they don't go orange and then red etc. Once they go orange, it's too late.
It can be done afterwards without removing the caliper. The clips only come from the agents and cost about R700 for the set.
Nice write up, let us know how the work and sound ?
Gizmo said:FYI textar are the oem bmw pads, just in the factory yellow box.
Iceman007 said:Good choice on Ferodo's. When I had my 2003 325i I had endless problems with ATE pads. Every 2000km my discs would be causing vibration. needless to say I wen through 2 sets of ATE discs and one set from Agents. It was an very expensive lesson. The ATE made very little dust and there was my problem they there compound was to hard and this causes bad heat transfer. So maybe it was a bad batch but since then it was Ferodo. I had to remove them in the end and replaced them with Ferodo pads and no further problems or squeals. Just remember your copper slip on back of pad
zippy320 said:Imo all these sensors are the same , End of the day they all get destroyed in the same way , I paid R90 or less for this sensor from Goldwagen and I think about thes same from a place in Dbn called martins spares.
The Textar pads ones I purchased from Autozone , I think Midas and maybe goldwagen has them as well as Diesel electric . Iv seen the banners at their entrance.
Morano is on this forum (moranor@axis I think) , You could PM him . Im sure he will be happy to help you.His helped tons of guys here .
Buy copper compound and place it on the BACK part of the pads (not the part that touches the disk) before installing it onto the piston and holder, I used that and there were no squeaks , Also check if the anti rattle metal piece is properly secured and not loose, BMW also sells that copper compound , but im sure its probably much more expensive . The brand I used was gold / brown in color and comes in a tube or a tin and I purchased that from Midas, But autozone has it as well, I purchased the tube and have used that tube for almost 5 years now. It really does last long. Also works on Squeaky house door hinges, though its messy for that application LoL
