Hi Guys, i need a bit of advice please. I removed the calipers on my 2009 e93 335i to have them powder coated. After reinstalling them i bled the system, once just manually actuating the brake pedal and releasing the bleed screw till the fluid came through clean and air free with the pedal stiff. Second time around i used the inpa procedure where the software activates the pumps etc and guides u throught the bleed procedure. Both times i drained about a litre of brake fluid through the system but whenever i step hard on the brake pedal it just goes soft and the DSC warning light comes on. There are no leaks or anything and as far as i can hear the ABS pump etc seems to be working. When i turn the car off and restart, all the faults clear automaticall but as soon as i step hard on the brakes, they all reappear. What else can i check or do or possible cause of this before i throw in the towel and take it to a dealership? Thanks
