Nastaliq
Hi Guys,
Need some advice.
I have an e90 lci, and I have started to notice that the door seals( the rubber tubing mounted on the door....you can see it when the door is open) has started to squeak and squeal when the car body flexes as it does when going over a bump, up a ramp from the flat road surface or coming down a ramp onto a level road, or even going over an electric gate track.
I need to know if the dealership will fix this, by applying some sealant to the rubber (something like gummi Pflege) or the SA equivalent which will probably be spit from a technicians mouth.
Or, should I get something to stop the noises and if so, then what should I get, from where and for how much.
For those of you that will suggest Silicon.......thanks, but no thanks, i dont want my rubber seals getting brown and brittle.
Thanks.
Need some advice.
Thanks.
