Bob Le'Ponge got a strut brace
ive been looking more into it this morning and it seems its better the push the towers together than pull them apart... the only way i can think of doing this with a normal bar is to put weights in the front foot wells...
camber can be changed as xmas was saying, but you do need to put alot of tension in to do this and too much will rip things over time... what i would do is make a mark on both sides, loosen it, jack/push the car and make sure the mark does not move more than 2mm this should make tension without any negative effects...
if you have a pre-tensioning bar they recommend no more than 1/3 of a turn from static so my guesstimate is under 2mm each side...
XMAX said:
@Technician - I will get me one of these probably in the next 2 weeks.
Would it be possible to meet up so that we could look into getting the brace etched.
Also, I am probably going to need a few blanks for De Swirling a 330D im buying.
PS. I am willing to pay for these services.
you should be able to get it sand blasted... all you need are bmwfanatics stickers... take them to a sandblasting place and they can use them to block off the metal
XMAX
@Moranor - Thanks for the reply.
I was actually wondering if I could get the brace engraved with the logo, though Sandblasting it does sound like a nice option.
@Techincian - I live in Midrand, but am willing to travel to other parts to get this done if possible, and economically viable.
if you dont already have the stickers you should try get them in a negative cut so you only have to sand blast the letters :)
Technician
no problem- any engineering requirements you need i can help.
send me a mail when you ready.
i can also do sand blasting....
