Hi All and Happy belated New Year!
I just wanted to get some insight and find out if this is an issue with this car or not.
I was driving the Mrs' car, slowly out a center thankfully, when I lost power steering and the battery / alternator light came on. Within the same 5 seconds I began seeing smoke coming from the bonnet.
I immediately turn the car off and pop the hood. It doesn't take long to see where everything is coming from. The crankshaft pully just decided to start breaking apart. There were pieces of rubber(?) that broke off and where smoking from the heat. It turns out that even though the belt was still around the pully, it couldn't make enough friction to turn the belt and instead turned against it which caused the power steering, alternator, etc to not turn.
I wasn't able to snap a picture when it happened due to it's location but it looked as if the middle of the pulley started breaking apart.
Is this an issue I didn't know about or am I just that special someone?
