Bmw f20 m sport calipers
Scotty88
So I a looking to upgrade my calipers on my 120d lci to m sport calipers.
I have found a decent set and was wondering if I would require new pads to pair with the m sport caliper?
Looked high and low online but no luck.
Thanks.
Sent from my SM-G998B using Tapatalk
Riaad
Events Organiser
If you are referring to the Blue M sport calipers - that is a completely different type caliper as compared to stock, Yes you will need different brake pads, and disks to match the bigger caliper.
you can search f series m performance brake retrofit (y)
Scotty88
Thank you sir, makes this far more unattractive now 🄲
Riaad
Events Organiser
Well only the cost is unattractive.
A set of second hand msport calipers is around 7k
Discs will probably cost around 6k
pads around 3k
and while you in there might as well upgrade the brake lines
and you might have to refurb the calipers as well.
Can easily be a R20k exercise.
