If you are referring to the Blue M sport calipers - that is a completely different type caliper as compared to stock, Yes you will need different brake pads, and disks to match the bigger caliper.
you can search f series m performance brake retrofit
A set of second hand msport calipers is around 7k
Discs will probably cost around 6k
pads around 3k
and while you in there might as well upgrade the brake lines
and you might have to refurb the calipers as well.
