Edwards095
I have a BMW 2006 530xi (n52 engine). Basically the serpentine belt got stuck into the engine and i took out all the pieces out of the engine and oil pan and reset the timing perfectly with the correct tool. Now i'm stuck with it still cranking.. Did a fuel pressure, compression, and spark test. They were all good!
The car cranks heavy like it wants to start but does not start. I am getting fuel, spark & air. I changed the throttle body, cams and crankshaft sensors. Any sort of advice would be greatly appreciated!!!
Codes received:
2A3F
2CF9
2D09
Codes received:
2A3F
2CF9
2D09
