Welcome to the forum and congrats on the N54! :thumbs:
Where are you based?
They are great cars but the n54's in particular are quite maintenance heavy, but mostly once off things.
A small to-do list off the top of my head:
- Get hold of BMW and ascertain if ALL recalls have been completed.
- Upgrade your charge pipe
- check and replace all vacuum lines
- check and replace your serpentine belt (these often go and cause catastrophic engine failure)
- Get an Oil catch-can
- look into the JB4 plug & play system, it can give you all fault codes and ability to diagnose and clear as well as the MASSIVE tuning benefits especially when MHD stacked. You can contact Rennzport who is a forum vendor for additional info (
[email protected])
- Check the oil filter housing for leaks, the seals often go and this leaks onto the belts and again, catastrophic failure.
- Check the water reservoir for any white spotting, these often blow the seal and would need replacing (agents)
That's all I can remember at the moment off the top of my head. The rest I can think of is modification related. :rollsmile:
