Sankekur
netercol said:how the hell does one "brake excessively" ??
pretty easily actually, with most road cars about 10 full on brake cycles (hard enough until just before the ABS kicks in) and the brakes will start to fade, that can be seen as excessively, as this is not what road car brakes are built for.
Bemused said:Surely, if the car brake system is original, you should be able to brake as hard as you like as often as you like without the brakes being negatively affected. If they burn blue or buckle or fade to buggery or squeal then it has to be a design flaw. That has to be BM's problem, not the owner/driver's problem. I'd look at the consumer protection act and see if there isn't a comeback to the dealership. It may be worth mentioning to them that you intend looking into that area if they don't want to co-operate in a reasonable manner. My 2c worth.
Not true at all, road car brakes fade pretty easily actually. And to my knowledge there are no brakes, or brake system in existence that allows you to brake "as hard and a often as you like". There are also other reasons why brakes your buckle and squeal that is not a design fault.
