black exhaust tips
deanbenn
Hi Guys
Where can I find black exhaust tips to fit onto my 330d LCI.
I dont like the droopy OEM tips. It needs to go...also anyone know of a good fitment centre that can weld on the normal chrome tips (if I cant find black tips:blueCry:) in JHB North?
Ralf*
HIYA
We do chrome tips from DEMON exhaust
we can also (with a day or three lead time) instruct our supplier to do modifications, such as all-black powder coating etc
single tips @ R400 each
dual Y-Tips @ R650 each..(neg)
deanbenn
Hi Ralf
Thanks for the reply...
Please explain what is meant by single tips and dual y tips? How much will it cost to fit two tips on the 330d exhaust? (parts and labour)
Ralf*
Single tip is when the rear silencer only has one outlet pipe, but you can make a single outlet pipe look like a dual pipe by fitting a Y-Tip piece
On the 330 I am sure that you have two seperate outlet pipes coming from the rear silencer, so two individual single pieces will be what is required
for two single tips to be fitted it would be around R800 maximum, depending on the style and size that you choose (all included)
For smaller diameter exhaust tips we can drop the total price for two individual tips to R700 (neg)
deanbenn
Thanks Ralf.....:coolShake: I want the diameter to be as close as OEM size.
Will most definetely pop in over the weekend!
MaX
The new 330d uses the same exhaust tips as the new 328. I just happened to have a set for sale... Check for sale section.
deanbenn
Hi Max
I see you have the whole back box for sale...I am just interested in the tips...The e90 330D LCI setup is different...
MaX
deanbenn said:
Hi Max
You can take the tips, get a box for free :biglol:
deanbenn
MaX said:
deanbenn said:
Hi Max
:YesNo: ahahahaha!!!
