Best M135i Mods
TheBaz
[font=Tahoma, Verdana, Arial, sans-serif]Hi Guys [/font]
[font=Tahoma, Verdana, Arial, sans-serif]New to this, have a 2014 M135i EWG. Been doing some research and so far what I can tell the best overall bang for your buck would be a catless downpipe, charge pipe, inter cooler, K&N drop in filter, GFB Dv+ and MHD stage 2+ [/font]
[font=Tahoma, Verdana, Arial, sans-serif]Anyone done the above or have any other options for the best bolt on’s ?[/font]
[font=Tahoma, Verdana, Arial, sans-serif]Thanks in advance [/font]
TheBaz
Thanks, Danny for the suggestions I believe the watermeth kit really helps to prevent carbon build up in the intake valves too.
M135i
Best mod is your right foot and your left arm (If manual), lol im being silly.
Chat to Danny he can help with the mods
Chrism135i
the best mod i have done especially for intake temps
TheBaz
Thanks, @"Chrism135i" win on my to-do list and adding WHP whilst cooling intake temps double win.
I see you have the same year and also the EWG M135i, what size intercooler are you running ? did the GFB DV+ noticeably improve throttle response ?
Also have you put or ever had aftermarket springs on your car trying to decide between Eibach and H&R...
AshG108
I have done the DV+ on mine, definitely made a god difference in throttle response in the higher RPM, holds boost better up top.
I currently have H&R Springs and it is an awesome add to the car...it really gives the car character and road-holding improvement is second to none. It helps keep that lose backside planted.
drcasin
at least 5" intercooler with CP  , DP and get Bootmod3 , that the best power gain , unless you want to upgrade turbos
