Baffled catch can Question
ShaunB
I fitted a BSH baffled catch can a few weeks ago, I would like to find out if there is a certain direction the pipes need to be connected up to it? inlet and outlet.
As My car use to breath quite a bit of oil out the dumpvalve etc but there is not a single drop of oil residue on the catch can dip stick after the install....
Twinz
Forum - Support
Ok.
I used to have a BSH OCC.
The in-out ports on the OCC does not matter as long as one of the ports go to the rear intake. I assume your Occ is connected at the high side PCV....which only collects blowby during WOT conditions. Its going to take quite a few months for your car to collect a decent amount.
ShaunB
Twinz said:
Ok.
Correct Sir, thank you. It is connected correctly then. Guess im use to POS 20VT VW motors that fill up a catch can in a week :roflol:
