Back lash on gear change
BaruschS
Hi all
I've been experiencing back lash on gear changes.
I have replaced main diff bush as i suspected that was the problem and checked gearbox mounts which seems to be fine as well as engine mounts but still getting back lash, any ideas on what it could be and what else I could check?:cry:
Gordvisr
BaruschS said:
Gordvisr said:
BaruschS said:
Gordvisr said:
what exactly do you mean by backlash ?
Hi Gordvisr
its a knock i get when leaving the clutch
Sounds Strange
have you recently had work done on the car before it started ?
no nothing done before this as i have only had a few months, i did the diff bush when this started
Check all bolts on bellhousing, there might be something there. sound like somethings loose.
DieselFan
Diff bush would of been a knocking on acceleration or deceleration not when release the clutch afaik.
Have you checked gearbox mounts?
Sent from Samsung S5
BaruschS
yes i have just did a visual inspection of the gearbox mounts tho did not actually take them completely off an check.
Gordvisr
jack the gearbox and then chack the mounts, if the mounts is worn and car is stationary you wont realy see if it is damaged or not.
BaruschS
Hi Guys thanks for all the help have not been able to get to it yet but driving down to Dbn tomorrow for the weekend, going to get my uncle to have a look at it as he is a master technician at BMW SMG dealership in DBN.
Jamaine
I have the same problem with my Diff on my car let me know on how you solved the issue but from speaking to some gearbox and diff people they said it just needs a service to adjust the play on the prop going into the diff or might need to replace worn bushes they said the knocking is caused by excessive play on the prop.
DROP IT - ZN
If its an E46...the problem lies with the propshaft
I had the exact same prob with my E46 and after replacing all diff bushes, gearbox mounts,cdv delete etc... Finally got the prop rebalanced and aligned along with new couplings etc and it was smooth thereafter
Philip Foglar
My Wife's 320i has always (since I bought it with 150k km on the clock) had a "donk" sound when changing gears and sometimes when engaging 1st gear while sitting at the lights. At the time when I bought the car I had the suspension and all rubbers under the car thoroughly inspected along with the subframe bushes and giubo flex disk couplers, all seemed fine. It doesn't do it all the time, but when it does it is obviously a bit annoying. Has not gotten any worse since and the car is rapidly closing in on 200k km.
Jamaine
Its the Prop phil get it checked out balanced and realigned you wont hear that donk anymore I am yet to get mines done had a mate do it just this week that past and it solved the donk
BaruschS
Hi guys thanks for all the help and advise, turns out it was actually the trailing arm bushes that were worn, car feels like new now after replacing them, and handles like its riding on train tracks around the bends
