Axis Engine Works
wilsonep
moranor@axis said:
Axis Engine Works is an engine workshop for fanatics by fanatics :rollsmile:
we use a scientific approach to engine work... no Guessing here it is done with the correct tools in the right way... this ensures the Job is done perfectly every time...
here are a few examples of work done that are documented on the forum:
2000 e38 740 Motor out
e39 Wagon Head Job
Crash's Jezebel gets a checkup
Axis Engine Works is located in Sandton JHB
Examples of what we offer:
All M5x, M6x, S5x and S6x motors Vanos repair and seal.
///M motor shim checks and replacements.
Timing chain guide replacement.
Cylinder head gasket replacement.
On any of these jobs a de-sludge could be done on the cylinder head whilst the motor is open. An oil change can also be done with LM oil...
we can also do code reading/diagnosis of engine problems
If you want your engine to run the way it did the day it came out the factory we have the tools and know how to make it happen :)
Is this Axis related to Peter K in anyway?
