Axis Brake Guide bushings DIY
This is the Install procedure for Axis Brake Guide Bushings. These promote more even pad wear and consistent Brake feel by not letting the guide bush flex allowing your brakes to squeeze evenly similar to multi piston BBK kits
Ivz_LaN598rHLNYDBxGWvQ3Vz77F6xpLVI84eEDslys=w1024-h590-no
Step 1 remove Caliper same as per Brake pad change plenty DIYs out there so best you find one for your car after that they pretty much all the same :)
tools needed for Axis guide bush install are:
Pliers
outside cir-clip pliers
19mm socket
4" or larger G clamp
Copper Grease
Next pull out the nasty squishy rubber guides
yrXsXF1o8vMVtcw-nwaV5rFFbN1BS0pGrJ-nn8cxXfI=w1024-h575-no
If the stuck you can even cut them as you dont need them anymore :cartel:
R5oIHN2MMATsog1W4W4X30uq3txWaxrGu6ItbNGJs6U=w1024-h575-no
Wire brush or sand the bore if there is any corrosion
Axis bushing goes in with the flange facing the Piston side of the caliper you can Grease this if you like but it is not needed with clean bores
v4C_zGxqMjUEU6YYIZXzL4pvOudK0o5zf4XIRYK1qwk=w1024-h460-no
the 19mm socket is used as a pocket to allow the Axis guide bush to seat properly
tsRxRhYEguiDZarGcbjMHrN-IjzyKB_9JK8XXY3BJjg=w1024-h479-no
Press in until the flange rests on the caliper housing
e6wSAQ8Bn59jwMOiq2tgz7OKGAOt94CEiU808_n4Mtk=w1024-h535-no
then it is circlip time :rollsmile: wear safety goggles
CPESvpozQ3fSYrrXKk8TxzX1FzzXGDAHZxFX7z8VjTw=w1024-h538-no
all done nice and Shiny
VGu4uWb7iDA7xypoP-ci2F3pDNaa8B3n_em_Ec2U5g0=w977-h643-no
Grease the Guide pins well with Copper Slip this should be re-greased at every Pad change to keep everything smooth
lEGs62-rdUHGyi6GbZNVHIaKy82wPHyp922p73Saftc=w973-h643-no
Old Squishy VS New shiny Axis guide pin
OSj7tv-AQf307u2kwu5pQ4X9hYEcpv8_JlyexibWcxM=w1024-h621-no
Guide bush listing here *CLICK*
Axis precision guide pins promote more even pad wear and consistent Brake feel by not letting the guide bush flex allowing your brakes to squeeze evenly similar to multi piston BBK kits
changed 1st post to include this :)
Xack
R980 for the rears then, cos somehow I only picture this being done at the back,lol
Xack
moranor@axis said:
confused :hammerhead: ?
Calipers? I mean these are for our calipers right, oh, two a piece, no more confused,lol
R 540 for a set of 4 this does Two calipers :) so two sets per car if you doing front and rear
Twinz
Forum - Support
Nice write up. Love the clarity of the pix. I mentioned this to a friend in this thread awhile ago...glad you came out with a kit.
Its definitely on my mod wishlist :clapper:
ugh I recognize that Caliper !!
Nicely done Sean - one suggestion include an extra cir-clip or two per set in case we loose one. Get this wrong and these things can fly miles, not to mention the way my garage "eats" sundries.
My EFT is en route.
