bmwforlife
Hi guys being a bit of a mechanical retard I need some info from you guys as to whether I am being ripped off or not .
My 540im had a bit of an ever present oil leak so I took it to 3 Services Independent BMW Specialists in Brackenfell.
Now the origin of the oil leak after much searching was found to be and I am quoting " one of the oil channels was improperly welded so it must be welded again'on the outside of the engine block .
The original quote for the job was about between 4-5k before they knew the origin of the leak and was for removal of the gearbox as well since it seemed to be leaking there .
So I am called and asked to come check the damage and told that the least laborious job would be to weld it and that it must go to an aliminium welder to do the job which I okay .
This was about 6 weeks ago so each week I pop in and am told next week there will be feedback .Importantly each time I pop in I use a different car depending upon my mood ranging from the M5 to the 645 .
So yesterday I pop in with the M5 and am told that the welding is done and it will take about a week to do fitment since they are fitting it in . I am also told that the cost for the aliminium welding is R5500 .
Isnt that a bit steep or don't I know my arse from my elbow ? If I add the original bill of about 6-7k to this we are looking at about 13k for fixing an oil leak at a very leisurely pace because they have had the car about 7 weeks .
What do you guys think ? Does anyone have experience with these guys ? I smell a rat but dont want to go guns blazing unless I have my facts straight
All assistance will be much appreciated .Oh ja no parts were purchased or replaced any time during this little procedure and the engine was removed but obviously not opened .
Thanks:thumbs:
Thanks:thumbs:
