MHuzaifa
Donovan2412 said:MHuzaifa said:I Have the same issue my car is currently standing at home in the garage , on my way back from the show on saturday @mall of the south i had the abs failure, transmission failure and drivetrain malfunction on the idrive unit and the lights appeared all over the dashboard and advised to drive at a stable or moderate speed then the rev counter and speedometer dropped to zero and after a few jerks the car switched off everything locked and i was unable to move the car at all, i tried jumping the car it started i drove for around 2km and the car did the same thing and switched off tried jumping again and the car starts but the moment i remove the jumper cables the car switches off, i then got another battery just to get the car home the car started and i drove the car home, from what i know i have a 652 battery in the car when tested it was fine but it doesnt seem to work on the car anymore and another thing when jumping the car the cables spark which means there is a short in the car im clueless as to whats going on, any idea what could be the cause of this as im very lost as well, i was having an idea that something was going to go wrong because on a cold or hot start the car struggles alittle to start and the revs are always higher then usual that is on cold start its around 1300rmp and then after a while drops to normal which i would assume is 500-600rmp but on a hot start it starts at 800-900rmp and stays there for awhile before going down and even on a cold start after it drops to normal i switch off and start again and it goes up high again and i have to wait again till it comes back down to normal.
Any help and advise would be really appreciated ...
How is your alternator doing?
Not sure havent checked that yet ...
i have the car booked in for tomorrow and sent the battery to battery centre to have it charged just to see if it could still be a battery issue, someone also told me it could be the battery harness that could be faulty,
just alot of stress as i cant moved the car at all...
