All New X1 (F48). World Premiere.
CocoPops
Physical
Length: 175.4 in (0.1 in shorter than E84 X1)
Width: 71.7 in (1.3 in wider than E84)
Width including mirrors: 81.1 in
Height: 62.5 in (2.1 in taller than E84)
Wheelbase: 105.1 in (3.6 in shorter than E84)
Front Track: 61.5 in
Rear Track: 61.6 in
Legroom Front: 40.4 in (1 in more than E84)
Legroom Rear: 37 in (1.5 inches more (standard seats), 2.6 inches (adjustable rear seat) more than E84)
Headroom Front: 41.9 in
Headroom Front (with sunroof): 40.4 in
Headroom Rear: 39.4 in
Headroom Rear (with sunroof): 38.2 in
Curb Weight: 3,662 lbs
Gross Weight: 4,720 lbs
Payload: 900 lbs
Engines / Transmission / Steering
xDrive28i: 2.0L B46 turbo inline 4 cylinder (1,998cc)
TwinScroll turbocharger, High Precision Injection, VALVETRONIC fully variable valve lift, and Double-VANOS variable camshaft timing
228 hp @ 5000 RPM
258 lb-ft @ 1250-4500 RPM
0-60 mph: 6.3 sec
Top speed: 130 mph
Preliminary EPA Mileage Estimates (MPG) – to be released
Aluminum crankcase and cylinder head
Forged steel crankshafts with integrated balance shaft drive,
Low-weight pistons, forged connecting rods, friction-reduced cylinder coatings
Map-controlled oil pumps.
8 Speed Steptronic Automatic Transmission (Aisin)
xDrive all-wheel-drive
single-speed bevel gear and a rear- axle drive unit with electrohydraulically controlled multi-plate clutch that controls longitudinal torque distribution. The two are connected by a two-piece drive shaft.
can divert up to 100% of engine's power to rear wheels
Electric Power Steering (EPS) with servotronic speed-sensitive steering assistance
Other highlights (some optional)
Power front seats with driver-side memory
Optional adjustable rear seats
40:20:40 seatback split
Optional rear seat slide forward or back by up to five inches
Optional rear seat tilts from 31 degrees to 1 degree.
Power-folding feature enables the rear seats to be folded at the touch of a button inside luggage compartment.
Cargo space increased by more than 15 percent
2 non-metallic and nine metallic colors at launch
Estoril Blue exclusive for M Sports package
M Sport Package (M steering wheel, M sport suspension, sports seats)
Premium Package, Technology Package, Driver Assistance Plus Package
Optional panoramic moonroof (larger than E84) (included in Premium Package)
Full LED headlights (included in Premium Package)
Head-Up Display
6.5 inch standard iDrive screen / optional 8.8 inch iDrive screen
Optional Harman Kardon HiFi system - 12 speaker / 360 watts
BMW Power.
Xack
very very pretty X1 , i just told a coleague the other day, that iam thinkin of a GLA maybe, now this jus changed my mind:praise:
Nastaliq
If you go test drive the GLA, you will find that it is actually very small inside.
also, the cabin is extremely dated, it doesnt scream modern, but 2006.
And for the price................. :thumbdo:
Caddy101
I like it!
But I have a feeling the price is gonna be ridiculous, then you start adding on options like headlights and indicators...
